пневмосхему на volvo fl10
Доброго времени суток, но после ДТП, все ресивера и трубки перемешались, теперь восстанавливаю, хотелось бы найти пневмосхему на volvo fl10. Спасибо.
Re: пневмосхему на volvo fl10
Так как ни винкода ни года ни номера шасси ни колесной формулы выкладываю первое что попалось FL10 4x2:
DIAGRAM1:
1 Compressor
1a Safety valve for compressor 15.5 (1.4 MPa) and LP4B (1.8 MPa)
2 Anti-icing reservoir. Excluded if air dryer is fitted.
2a Air dryer
Diagrams 2, 3, 4: single tower
Diagram 6: twin tower
2b Dry tank. Diagrams 2, 3, 4
3 Air filter for compressor intake air
4 Pressure regulator
5 Quick release valve
Alternative control valves:
5b Pilot valve (PI-VENT). Line added from x.
5c Two-stage control valve (R-VENT2) in combination with bogie lift valve 35. (Line y).
Diagram 4: S-ride
Diagram 6: Line y from bogie lift bellows
5d Relay valve. Diagrams 7, 8
6 Brake cylinder, front wheels
Diagrams 1, 2, 6, 10:
Single diaphragm cylinder
Diagrams 3, 4, 5, 7, 8, 9:
Spring brake cylinder
6a Single diaphragm cylinder, 8x2, 8x4
FL (F Australia): 1st front axle
F: 2nd front axle
7 Air pressure gauge
FL: Electrically controlled with sensor 8c
F: Direct sensing, dotted lines
7a Air pressure gauge for system pressure, air suspension. Diagram 6
FL: Electrically controlled with sensor 8d
F: Direct sensing, with line to wet tank, dotted lines
8 Low-pressure indicator: from respective rear wheel circuit reservoir. In-built in gauge. (Connected to warning lamp, service brakes).
8a Low-pressure indicator: Parking brake. (Connected to warning lamp, parking).
8b Low-pressure indicator: Reservoir parking brake and trailer brake. (Connected to warning lamp, service brakes).
8c FL: Sensor, electrical. For gauge 7.
8d FL: Sensor, electrical. For gauge 7a.
9 Brake light switch FL with hand control D: Only pos. E. Pos. 9 not applicable
10 Footbrake valve
P = Primary circuit, S = Secondary circuit
11 Air tank, front wheel circuit (certain variants 2 tanks)
12 Air tank, rear wheel circuit (certain variants 2 tanks)
13 Air tank, parking brake
14 Air tank, wet tank
15 Non-return valve, parking brake
16 Non-return valve, wet tank (Diagram 6: in-built in air dryer)
17 Blocking valve
18 Tank valve (tyre inflation nipple)
19 Hand control, parking brake
20 Constriction valve. Diagram 6
21 Safety valve (0.93 MPa)
21a Safety valve (1.3 MPa)
Diagram 6
22 Drain valve/unloading valve (in-built in the air dryer)
23 Test nipples
4 for tank pressure
3 alt. 2 for operating pressure
Diagrams 6, 9, 10: 1 for bellows pressure on the load-sensing valve
24 Four-circuit protection valve
25 Distributor nipple. Air output for compressed-air operated equipment.
25a Filter
26 Drain valve (tanks 11,12, 13,14)
27 -
28 Test plug 3 or 2. With quick release valve 5, plug in front wheel circuit excluded.
29 Load-sensing valve (alt. equipment incl. test nipple)
Diagrams 1, 2, 3, 5, 8, 9,10: with in-built relay valve
Without load-sensing valve: The valve is replaced by a relay valve
29a Load-sensing valve controlled by the air springs bellows pressure z
(In-built relay valve)
Diagrams 6, 9, 10
30 Two-way valve
31 Relay valve for parking brake
32 -
33 Brake cylinder drive wheel brake: spring brake cylinder
33a Brake cylinder, trailing wheel resp. rear drive wheel: single diaphragm cylinder
Diagram 6: Spring brake cylinder
33b Diagrams 9, 10: Brake cylinder
16 tons: single diaphragm
20 tons: spring brake cylinder
34 Relay valve service brakes, rear wheel 6x2, 5x2. Diagrams 4, 7
35 Bogie lift valve for 6x2 truck with two-stage control valve 5c
With air suspension or S-ride bogie: bogie lift valve excluded and line to 5c is connected to lift bellows control pressure
36 Solenoid valve ABS. Diagrams 1, 4, 5 (four valves per truck, irrespective of number of axles).
51 Pressure limiting valve. Diagram 6
52a Overflow valve. Air to air suspension system. Diagram 6
70 Air to air suspension system. Diagrams 9, 10
x Line to pilot valve 5b
y Line to two-stage control valve 5c
z Control lines from air bellows
Additional for vehicle equipped for trailer brakes
A Control valve for trailer brake (with constriction valve)
B Operating line, trailer brakes
C Emergency line, trailer brakes
D Hand control, trailer brakes (alt. equipment)
E Brake light switch (only with hand control)
F Two-way valve (only with hand control)
DIAGRAM1:
1 Compressor
2a Air dryer
Diagram 4: S-ride
F: 2nd front axle
10 Footbrake valve
17 Blocking valve
Diagram 6
23 Test nipples
4 for tank pressure
25a Filter
27 -
Diagrams 6, 9, 10
30 Two-way valve
32 -
спасибо, буду разбираться, а вообще машина 1990 г, рессорная, 4х2, если принесет полезную информацию-вин
YV2F2B3A1LA343103
YV2F2B3A1LA343103
