volvo d9b MID 128 SID 32 FMI4
Добавлено: Сб сен 19, 2015 1:24 pm
Егор70
volvo d9b MID 128 SID 32 FMI4 Добрый день помогите расшифровать ошибку. на http://kodtruck.ru нет. :( Спасибо.
Re: volvo d9b MID 128 SID 32 FMI4
Добавлено: Вс сен 20, 2015 2:15 am
MID 128, SID 32, Wastegate output driver
FMI 4 – Voltage below normal or shorted to lower voltage
Fault code explanation: Faulty regulator / Faulty regulator circuit
Fault indication: DCU: Engine warning in DCU display.
CIU: None.
Flash code
Electrical fault: None.
Value fault: None.
Conditions for fault code: The voltage on pin B38 on the EMS2 deviates from normal voltage value.
Possible reason: • Open circuit in wastegate battery voltage supply cable.
• Short circuited wastegate regulator signal cable to battery negative or
to lower voltage.
• Faulty wastegate regulator.
Suitable action: 1 Check all cable and connectors between EMS2 and wastegate regulator.
2 Change wastegate regulator.
Добавлено: Вс сен 20, 2015 1:48 pm
pino
вин шасси тока так
а так жалуется на регулятор давления надува
